February 25, 2021
Through a combination of different attributes, Silicon Carbide (SiC) has established itself as the premier semiconductor technology for the electric vehicle (EV) sector – with devices outperforming those based on conventional Silicon (Si). Its advantages include elevated voltage ratings, superior power conversion efficiency levels and the ability to deal with heightened temperatures.
On-board chargers (OBCs), DC-DC converters and traction inverters all benefit from SiC, with the ongoing process and architectural enhancements certain to increase its already considerable appeal. Such enhancements will extend the reach of this wide bandgap material’s operational parameters and further mitigate the power losses experienced. At the same time, the economies of scale that larger production volumes allow, will mean that it can hit more attractive price points.
Recognizing the nature of these dynamics, and the urgency with which a viable solution needed to be found proved pivotal in driving UnitedSiC to develop its fourth generation (Gen 4) SiC technology. The specification improvements that have been made over the SiC technologies offered by other vendors are illustrated in Table 1. Here the new 750V-rated UJ4C075018K4S SiC FET is compared with three alternative 650V SiC MOSFETs, plus a Si-based super-junction FET device. Even though the Gen 4 SiC FET has a markedly higher voltage rating, the on-resistance per unit area of this technology is two to three times better than for the other SiC MOSFETs and more than an order of magnitude better than the Si FET option. This means that comparable performance can be achieved in much smaller format packages.
Technology | G4 SiC FET | SiC MOS1 | SiC MOS2 | SiC MOS3 | SJ (fast) |
Voltage Rating [V] | 750 | 650 | 650 | 650 | 600 |
RdsA @ 25C (mohm-cm2) SiC | 0.7 | 2.1 | 2.1 | 2.8 | 8.0 |
RdsA @ 125C (mohm-cm2) SiC | 1.26 | 2.60 | 2.60 | 4.30 | 14.40 |
VTH | 4.8 | 4.5 | 2.3 | 3.1 | 3.0 |
Preferred Gate Drive | 0 to 12V | 0 to 18V | -4 to 15V | -5 to 18V | 0 to 10V |
Qg.V (uJ) | 0.36 | 1.13 | 3.57 | 3.73 | 2.51 |
VFSD (25C) [V] Nominal Current, VgsOff | 1.6V (50.0A) | 4.0V (38.3A) | 5.4V (55.8A) | 4.3V (50.0A) | 1V |
125C Rdson x Eoss [mOhm-uJ] | 372.0 | 732.6 | 714.0 | 754.0 | 826.5 |
125C Rdson x Coss,tr [mOhm-nF] | 8.70 | 12.1 | 8.8 | 13.7 | 108.2 |
VF x Qrr [V-uC] | 0.17 | 0.96 | 2.33 | 1.59 | 1.56 |
Rdson, Nominal | 18m | 27m | 15m | 20m | 15m |
The reason for the ultra-low on-resistance per unit area is the high-density trench SiC JFET structure incorporated into the SiC FET. This is co-packaged with a low voltage Si MOSFET. The reduced area of the SiC JFET means that an extraordinarily low on-resistance will be exhibited for a given chip size (Figure 1). Conversely, a smaller FET with lower capacitance could be utilized while keeping down at an acceptable on-resistance.
To reduce the electrical and thermal resistance values (and keep the associated losses in check) the SiC substrate has been thinned considerably. To maintain structural integrity, the thinned substrate is attached to a Copper (Cu) lead-frame via a silver (Ag) sintering material (which has six times better thermal conductivity than standard soldering materials).
Other advantages that are derived by UnitedSiC’s Gen 4 SiC technology include a dramatic lowering of the associated gate driving losses – as shown when compared to the other devices cited in Table 4. This means that switching speeds can be as much as trebled without any risk of the gate drive ICs becoming overheated. There I no need for a negative gate drive. Thanks to low forward voltage drop (VFSD) and minimal reverse recovery charge (QRR), a superior VF.QRR figure of merit (FoM) is exhibited. This cannot be matched by what any device currently on the market can deliver.
Figure 1: On-resistance per unit area comparison between 750V-rated UnitedSiC Gen 4 SiC FETs and rival 650V-rated FETs
SiC is already making EV drivetrains and battery systems more efficient, allowing performance benchmarks to be attained that are way beyond the confines of Si semiconductor technology. The advent of next-generation SiC technology will further affirm its value in relation to the wider proliferation of EVs across the globe over the coming years.
For more detail, look at our recent article in the January issue of Power Systems Design.
