September 14, 2021
    Join Jonathan Dodge, Principal Applications Engineer at UnitedSiC, as he demonstrates the new Active Neutral-Point-Clamped (ANPC) Voltage Source Inverter topology and the PWM strategy and modulation options you can use to evaluate UnitedSiC devices in this topology using FET-Jet Calculator v2.0.
    Explore the Gen 4 750V SiC FETs: https://bit.ly/3nkt7zC
    Use the FET-Jet Calculator to find your ideal device: https://bit.ly/3r6FeBo
